15 inch wheel on 72 Demon
andysauto1
Flora, Il.
Anybody out there running 15 inch by 8 inch wheel with 4.625 back spacing on stock 8.75 rear end, if so what size tire. My car is a 72 340 Demon
You will have to buy them special. No 15's in the small bolt pattern. But you knew that.
255-60-15 with a clearance cushion - I tried a 275 on but its too close to the spring for me. 71 Duster - ought to be the same. this is the small bolt pattern wheel from wheel vintiques
I ordered factory SB mags from Summit racing and had them make a set with 4 1/4 BS . Here they are with 275 x 60 on a duster
