I should have a few. Anything else? Where are you located?This is mine, I believe it's correct but it appears to be missing the right side as there's only 1 screw holding it on the left.
And it's missing the fan switch, obviously.
NY.Where are you located?
Maybe a few pieces of trim, an emblem I think, I'll check.Anything else?
