WARNING!!! if you use the stainless versions, the flare fittings are harder to seal! The stainless is just much harder than the original mild steel (but then it never corrodes, either) After struggling with them for way too long, I found a post here with a link to copper flares that go inside the stainless flare and seal up easy peasy.
