GoodysGotaCuda
Mr. Goody
Fast or slow, lets see if we can get a on-going thread here on what everyone is running and with what. Quote this first post and fill in your info.
:wav:
Car:
Weight:
Track Conditions (Elevation, Heat, Humidity, Density Altitude, etc, etc):
Slip
Reaction Time-
60 foot-
330'-
1/8th Mile-
MPH-
1000'-
1/4-
MPH-
Build - Engine
Cubic Inches:
N/A, Forced Induction (Pounds), Nitrous (HP Shot):
Cylinder Heads (Aluminum, Cast, Ported, etc):
Compression Ratio:
Cam (Hyd/Solid/Roller - Specs):
Intake Manifold:
Carb/E.F.I:
Exhaust:
Ignition:
Transmission
Type: (904, 727, 4speed, etc):
Shift Kit:
Torque Converter (Brand/Stall/Size):
Rear
Size (8 1/4, 8 3/4, Dana, etc):
Gear Ratio:
Differential:
Suspension/Tires
Spring Style (Cal-Traks, S/S, Stock):
Shocks:
Tire Size:
Tire Type (Radial, Drag Radial, Slick):
:wav:
Car:
Weight:
Slip
Reaction Time-
60 foot-
330'-
1/8th Mile-
MPH-
1000'-
1/4-
MPH-
Build - Engine
Cubic Inches:
Compression Ratio:
Intake Manifold:
Carb/E.F.I:
Exhaust:
Ignition:
Transmission
Shift Kit:
Rear
Gear Ratio:
Differential:
Suspension/Tires
Shocks:
Tire Size:
