Puts the throttle cable in the correct spot, as 340's never had 2bbls on them.
The pin must be for the kickdown pivot.
Your doing a great job, but after all the effort, why cobble it together ?
Especially when all the parts are inexpensive, and available.
Nice photos! You need carb studs though and I hope the end of the throttle spring isn't in the cotter key hole on the carb side.
Part number thru Brewers for 6pk coil bracket is CB407.
Last tip: Paint the manifold bolts, "After" you install them.
OGreat thread, I am getting schooled as I am putting the same outfit on my 273. You are doing stellar work and it is fun to look at. Dont get a ticket when it is tuned and doneO
DR:coffee2:
Here's what tool you need to torque those hard to get at spots.
Just got back in after installing the valve covers....
Looks like there's more work to do. I truly appreciate all the help here!!!
Yes they did. They had 3.
Nice job and good on you for making things work that you have on hand!
What does the famed 340 throttle cable bracket do for the problem?
