Mopar mopar forum
 HOME  FORUMS   FABO STORE   MEMBER PHOTO GALLERY  CHAT  MEMBER CLASSIFIEDS  MOPAR VIN DECODER   REGISTER
 VIDEO GALLERY  NEW POSTS  TODAYS POSTS  SEARCH  CALENDAR  B BODY MOPAR FORUM  E BODY MOPAR FORUM
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Body / Interior / Trim
headliner install 101
Thread Tools Display Modes
Old 08-25-2007, 10:17 AM   #1
sweatybetty
Senior Member
sweatybetty's Avatar
well i bought a headliner on ebay from this guy
http://cgi.ebay.com/ebaymotors/BARRA...spagenameZWDVW
excellent product and fast shipping. lots of extra material around the edges for trimming and even an extra square yard of material. i highly recommend this outfit.
anyhow first step was to get the bows in and get the bows hooked in the car. the bows are color coded front to rear and only fit one way. make sure to mark the if you remove them and the paint is gone.
the front bow should be tilted toward the back of the car. this allows the liner to be pulled tight to the hooks along the wind shield. start in the center, working toward the doors, back and forth. also, heat is your friend. i used a quartz heater and rolled the side glass up trapping the heat inside. the liner was warm to the touch and this helped alot.
once the front is hooked, start on the rear. the rest of the bows are loose in their sockts allowing the liner to be pulled to the rear. starting in the center, pull the liner TIGHT, going side to side. i pulled with 1 hand and used a 3" putty knife to hook the liner on the pins.
now for the sides. alternating from sise to side, pull tight and hook maybe 2-3" at a time. i started in the middle of the window opening and worked out from there. dont trim yet!
the front pillars and rear sail panels are the pain. DO NOT TRIM ANY MATERIAL until you get these parts glued and the glue is dry. dont ask how i found out!
i used pliobond contact adhesive. this is a commercial type and works great. $4.95 at ace hardware.
i pulled the liner kind of snug to the edges and marked with a sharpie to give me an idea where to put the glue. brush the glue on the body, and on the liner and let dry. when its dry to the touch brush another coat on the liner and let that tack up. while its still sticky, pull liner tight and press into place. the glue will hold it now. this took me a few times until i was satisfied and got most of the wrinkles out. on my car, the window seals cover the liner along the edges, so make sure to glue these edges also. take your time. it wasnt easy but wasnt as hard as i thoght it would be.
while there are some wrinkles, im satisfied with the outcome. heres some pics.
also i used a hooked blade in my razor knife. this worked better than a straight blade and helped prevent any oh shits.
sweatybetty is offline   Reply With Quote
Old 08-25-2007, 10:20 AM   #2
sweatybetty
Senior Member
heres the glue
Old 08-25-2007, 11:38 AM   #3
65s
Senior Member
65s's Avatar
That's awesome Sweatybetty! So you glued it along the back window at the top, right where it hooks into those hooks? Or did you glue it just before the hooks on that flat piece of metal back there?
I had a guy do my headliner a few years ago with the glass in, but I'm convinced you can't it that way. The back part has always fallen down. I glued it, pulled it, and eventually screwed a piece of trim up into the sheetmetal to hold it, which now holds it but doesn't look the best. I will eventually do the headliner again.
Thanks for the photos!
65s is offline   Reply With Quote
Old 08-25-2007, 11:12 PM   #4
sweatybetty
Senior Member
thanks. i glued it all along the very outside edge. the one thing i didnt like was the liner is perforated so the glue kind of oozed through the holes in a few spots, not real bad but i can see it. i think the best way would be to pull the glass because the window seals cover the liner edge.
Old 08-26-2007, 12:47 AM   #5
rumblefish360
Dynamic duo at the ready!
rumblefish360's Avatar
rumblefish360's Flag is: United States
WOW! Dude. this is great. Thanks for the posting on this.
rumblefish360 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
which way to install offset bushings??? mbaird Suspension, Steering and Chassis 11 04-16-2007 07:59 PM
headliner install 66dartman Body / Interior / Trim 2 02-09-2007 07:08 AM
Headliner Installation 73dart_swinger Body / Interior / Trim 6 01-17-2007 05:45 PM
Headliner install? moparlee Early A-Body Discussions 21 09-25-2006 09:27 AM
Install headliner slim17265 Body / Interior / Trim 4 11-27-2005 04:24 AM
FABO SPONSORS
Limited Edition FABO T-Shirt
Mopar T Shirt
LAST CHANCE! Get Yours Today!
Dales Cuda Shop
Rosevilla Mopar Parts
Charger Specialties
Performance Suspension Technology
Inertia Motorsports
1960-1976 Plymouth Valiant - 1963-1976 Dodge Dart - 1964-1969 Plymouth Barracuda - 1971-1976 Plymouth Scamp
1970-1976 Plymouth Duster - 1961-1962 Dodge Lancer - 1971-1972 Dodge Demon - 1971-1981 Valiant Charger (Australia Only)
air suspension | suspension parts
Powered by: vBulletin Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 0.16666 seconds with 12 queries
