Dream 67 440 gt dart
Ptdartfreak
Mopar freak
CA (unfortunatly)
Well finally the time has come where the firebird is sold and my project is here. And some have known about the car but havent seen pictures. This car is a very rust free car only rust may be on the drivers side floor and a tiny bit in the trunk.
440
B body 4 speed
Ford nine inch shortend to 44 inches
springs moved in
and tub almost done
Lightend crank
lightend rods
lightend flywheel
906 heads
crappy eddy intake
blaster coil
msd wires
consle
buckets
Parts i need and let me know
Rear drivers side tailight
rear bumper
seat covers Black
carpet black
headliner black
dash cap black
better intake
850 demon or holley
big block k member
and i will add to this as i go
i plan on getting rid of the motor plate
selling the four speed
getting my dads 5 speed
restoring the interior
my cousin has a set of bigger valves and milled out 906 heads
finish the tub and the rear end
pics are before i washed it
What k-frame is in it? Can you get Shumacher mounts or have the mounting pads been removed from the k-member?
Cool car. That intake is not that bad with an open spacer. Should run good. Its not the best, but if its all you have I'd run it.
Wow, talk about a sleeper. That car looks to be a real grocery getter until you open the hood, or come up on the rear end of it. Sweet project.
Yes do keep at it and don't forget to keep posting pictures. Eventually when my Duster is done I plan on the 360 not lasting long, although there's only about 2k on a rebuild that was done 15 years ago the engine hasn't even been turned in over 12 years, and going w/a 440. So I'd like to see as many "reference" shots of the engine compartment, tunnel and rear as you can share during you build.
Have fun.
i took the rear and the leafs out today this week i will be painting and welding on the spring perches and the rear will be put back in next weekend
i have a just like new edelbrook torker 440 manifold i will let go shipped to you $120.00 CAN SEND YOU PICS IF YOU ARE INTERESTED THANKS
I am busy smoothing out the rear end and my attention to detail is kicking in. Once i am done there it will be diped and everything put back together. One spring has been sandblasted i need some more sand to do the other. Also scored this free welder Craftsman 20559-MIG WELDER
Wooooo congrats Chad! You'll have fun building and running that little baby. Keep us posted on your progress.
I MADE THESE INSTEAD OF PAYING $175
took the measurements of the mopar ones
but this is a thicker steel
im happy with them they will get welded in soon
just a bit squaring up left to do on them and some sanding
excuse the welds on the inside i welded on the inside and the out ground down the outside welds and leaving the ones on the inside
