thorstenn
Member
Hi all,
Witch is a better motor for street n strip. 340 or 360 and why???
Thank you ,
Thorstenn
Thank you ,
Thorstenn
the 360 is smaller but wouldnt a .040 over bore put them at the same displacement?
plus if you throw a rod you'd be able to find a replacement 360 easier than a 340..
I think it's a mute point...360s are every bit as good as 340s. They just don't have the fame because Dodge never built them as Muscle motors. If they did, I'm confident IT would be the famed smallblock and the 340 would have the status of 318.
I think it's just a matter if the owners wants to be able to say that he has a 340.
snowymountainman said:Now your getting somewhere but consider this....How many people do you know that can tell them apart? Especially if you hand around any ferd or chebby fans. Those little numbers on the front left side of the block near the head are awfull hard to read if you paint the block. Throw a pie tin on the top that says 340 4 Barrel and you got a 340!! I'd be just as proud of a 360 that I built though. Run What You Brung......Nuff Said. :headbang: [/b]
68dartgts said:i have ran both motors the 340 run circles around the 360 every thing being the same (cam , heads, intake, carb)
thorstenn said:I have two 360's and one 318 all 74 or newer. I saw an ad for a 340 block for 200.00 and a friend said he might have heads still for a 340 in his garage, thats why the debate.
