8&3/4 lube fill amount Q
Rapid Robert
Lincoln Nebraska
I jumped the gun & brakekleened the pumpkin well before I was ready to lift it up/in. it in now & my Q is can I fill the housing up & not have it leak out the housing end(s). I don't want the pumpkin to rust. I dont have the axles yet but the end seals are in place. thank you for your time .RR
You might. Why fill it. Throw a quart in for now. When you spin it occasionally you will lubricate it.
I drilled a 1/2' access hole in the rear at the top of the curvature (IMCA rules) & added a slight bit. the nose got tilted down as I was manuevering things so I'm sure the nose area at the front of the pinion got lubed then with it bolted in I turned the gears backward/forward a few times to lube the gears so it should be good. thanks guys for the help/insight, RR
