Ok guys, I have put an Edelbrock 600 on my 318, I have installed the Edelbrock 1481 adapter but the one picture that showed how to install it wasn't very clear. Im also not sure how to hook all the linkage back. Does this look correct?
Return spring on the bottom would want to open the throttle, I thinks . also, yes, usually you would have the throttle cable and kickdown on the same, like a TQ set up. However, I've done like he has done and it's worked.
Ok, Thanks guys I think I get it now. I appreciate your help, kinda new at this as you can tell. I think I will need to get the longer style of pin(pic1) because the pin I have(similar to pic2) only has a spot for the throttle cable and not the linkage.
Millions of Mopars came with Carter carburetors almost identical to the Edelbrocks and not one of them ever had that stupid linkage adapter. They are totally unnecessary.
