High build suitable for an apartment garage?
thejohnnyguy
Young Gun
Charlotte
Does anyone know of a good primer that won't send the neighbors running? I would really prefer a roll-on primer... I am working on a VERY tight budget and this car's not going to see Barret-Jacksons anytime soon... I'm tossing back and forth the idea of doing the whole paint-job in the garage, only because I can't afford to pay someone to do it. any suggestions? the filler I got for body work is Evercoat Rage Extreme, since I heard it's virtually pin-hole free and waaaaaaaayyyy better than bondo!
There are low VOC primers available. For the budget conscious you might look into the Summit/Eastwood line of paints which are repackaged Kirker products. Can also be found on smartshopper.com. Matrix isn't priced too bad either. But I guarantee if you start buying PPG or any other big name products you will spend a fortune before you're done.
Low VOC or not I don't think you'd get away with painting in an apartment without some odor. Isocyanites are nasty.
