Ok here we go. I can't post Pic's in a PM so i have started a thread to show the pic's to Yellow Rose and anyone else that is interested.
You told me i should take lot of notes this is all the notes for my 340/360 head porting.
Here is the Clay Closed Closed Chamber
Notice that i have already tubed the pushrod tubes
failed attempts to raise the floor and make rounder/larger SSR
The next 2 pic's are the before.(there is a factory machined flat spot at the top of the seat. picture don't show it.)
And after when i finally got it to flow past. 500 lift. (said it was .550, i was mistaken)
That green looking stuff is called Z-spar. two part epoxy that when mixed turn that color.
Those scars are for sanding/shaping it with 36 grit sandpaper.
There you go ;)
There you go ;)
