Programming an MSD Digital E-Curve Pro Billet Distributor?
69_340_GTS
Torrington, CT
Can anyone recommend the best advance curves, mechanical and vacuum, to program an MSD Digital E-Curve Pro Billet Distributor? It’s in a 340 with 10.5 compression, 268°/.464” Comp cam, Eddy heads, 600 Eddy carb., headers. Right now it runs good with around 15° initial, 20° centrifugal starting at around 1000 RPM, all in by 3000 RPM. So I’m thinking "Curve F" , but I don’t know where to set the vacuum. Here are the available curves:
I know this is old, but what did you settle on? I bought the same distributor years ago, and want to put it on the 408 I'm building now.
I'm going to go for it with a quick Fuel 750 SS mechanical secondary on a single plane TF manifold. If I don't like it, I'll upgrade to the Sniper. Thank You for your answer. Paul.
