super six kick down throttle lever
hosehead
Springfield Mo
Hey everyone, I'm hoping one of you could point me in the right direction. I have acquired a complete super six set up with the exception of the throttle pressure lever on the trans. Is this unique to the super six kick down or just the year of the 904 trans? And I promise I've looked for the answer prior to asking here. Lol.
Thanks all.
on the right 3751-551 2.40 between large holes on the left 2899370 727 tranny 2.61 between holes and bent wrong
on left shiny one bent to left 727 on right 904 bent to right this is done for clearance reasons
727 goes up 904 goes down. they start in the same plane but change direction just past the small hole
Bulletin from back in the day. These things would get mixed up at factory too. Also the part about the lenght between holes center to center, important adjusting will not change lever ratio. That .130 too long is the thickness of a penny on top of a nickel.About 0128
Cut at bend measure center to center of large holes grind till measures 2.400,flip the other way bend goes down ,weld back together that will give the angle and lenght. Same as part number 3751-551 for super six
Back in the day the lever would get lost or mixed up or just needed custom lever,mostly just a little bit shorter
The super six bell crank was directional change only one to one ratio. What are you working on, does it have bell crank one to one ratio what about length of lever. wonder if super six linkage will work on all older trannys?
Thanks all.
Did you get what you need on this? I have a complete Super Six kickdown I could dig out for photos if you still need details.
I think so. Old Kimmer has sent me what I believe is the correct lever. I'll receive it next week, I think.
