Temperature Sending Unit
mopardude62
Missouri
I have a 1967 Barracuda with the 273 engine. The temperature gauge has never worked. If I ground the purple wire that runs out to the sending unit the needle moves all the way to Hot and beyond.
This weekend it was nice and I went for a cruise. The temperature gauge never moved off of cold even after an hour on the highway. I started thinking and just for fun when I pulled into the garage I pulled the wire off the sending unit and measured the resistance between the tip of the sending unit and the threaded base, here's what I had:
Hot just garaged 276K Ohms
After sitting for an hour 440K Ohms
2 hours 2.6M Ohms
3 hours 3.0M Ohms
Overnight 6.7M Ohms
These resistances seem very high to me. I thought I read somewhere Chrysler changed the way the gauges worked in the early 70's. Is this true? Could I have the wrong sending unit? Were they different between years? Any help would be appreciated. Yes it is full of coolant.
X2 on the sending unit for the idiot light. Find the sender for a guage, and I'll bet everything works as it should.
