jeryst
What would be the nastiest set of Mopar heads available for a 340? I'm talking about actual Mopar heads, not aftermarket. This will be for a street car.
flyboy01 said:Stock would be 5.9 Magnum heads, they will out flow any other stock heads. The new HD replacement heads do even better, you can get them from Hughes Engines for about $650 a pair bare. Aftermarket "mopar" heads would some of the "W" heads Mopar sells. In my opinion, I would go with the new Edelbrock victor heads.
jeryst said:What would be the nastiest set of Mopar heads available for a 340? I'm talking about actual Mopar heads, not aftermarket. This will be for a street car.
lead69 said:Stock there are only marginal flow differences between all the common four barrel heads-unless you spend extra for a ta or x head and you could easily beat there flow numbers with a little work on any smog 360 or j head.A bowl hog and blend and a stock head will make great power on the cheap.
Just a few years back, a company made a custom set and then made them for the public.Did they ever make such a thing, or would they have been aftermarket?
rumblefish360 said:On the HEMI head for the small block.
IMO, all things dependent, YOU may **** us not on what you seen and were told, but I have serious doubts on it. Not to call you or him lier, but whats the chances you have seen these heads.
BJR Racing said:Here's a question that I get most all the time, how do you get a small port to flow so much.
