Which speedo gear for 3.23 and 255/60/15?
Mopar92
Lewisburg tn
I’ve looked at 3 online charts and all 3 are different ! Ha. Any real world experience with this setup in my 833? I have a 34 that came out of it. Thanks guys.
255/60 15 is a 27" tall tire.
3.23 Rear Gear
Speedo Gear - 32 Teeth
The teeth are a little rough in some spots but it should still give me an idea.
Yeah google found me 3 charts and 3 different gear numbers too.... as stated in my original post. Thanks though.
Sometimes it requires trial and error. Not all speedos are created equal. I used the chart for mine recently and I tried a 33T and then a 34T. At the end of the day one way +3-4mph and the other was - 3-4 mph so it was as close as I could get it.
I used the Waze app on my phone for comparison.
I also looked at a few different charts but all pointed to the same gear in my case.
GPS Speedo for our 69 Fastback
All new Speed Hut gauges and custom dash. Freeze Plug where the speedo gear would be. :thumbsup:
----o00o--'(_)'--o00o----
Nothing is exact for sure. I looked up your tire size and the chart I found said it was a 28" tire. Heck, the tire size carts can't even agree. If that was the case you need a 31 tooth. Apparently there is no correct answer here.
I guess I’ll put in the 34 and see how bad off it is. Was just trying to save some hassle.
255/60-15 is a 26.05" tire. Every chart I have used says to use a 33 tooth gear with 26" tire and a 3.23 gear. I think the real problem is that for it to be "perfect" you'd need it to have more than 32 teeth, but less than 33 teeth.
255/60 16 Was a typo... Fixed it.
Two tires from Tire Rack. Both 255/60-15
BF Goodrich Radial TA 27.1"
Cooper Cobra Radial GT 27"
Still say run the 34 but think 32 will be closest.
