How To Measure For And Correct Valve Spring Height
  1. RustyRatRod
    This is how I measure for and correct valve spring height. Very simple process. all you need is a 35 dollar tool. It's called a valve spring micrometer. This is essential for correctly setting up valve spring heights and making sure you have the correct installed height for the correct seat and open pressures. Failure to do this can have catastrophic results. As always, this is how I do it. Thanks for following along.
    Share This Article
