1) install the floating roller into the long slot of the window mount. I should mention that in the picture the roller is upside down the black roller actually goes into the mount not the white one.
2) install the window mount into the quarter panel.
3) install the regulator. Note you will need to rack the regulator to one side to install with ease.
4) there is a small white roller on the arm of the regulator that needs to go into the slide attached to the inside of the interior panel.
I tried to get a good pic of it hope it is clear enough..
5) install the rear black roller into the same slot that the floating roller is in.
6) now install the lower black roller into the middle slot.
7) install the lower window guide roller into the lower slot.
8) this was a little tricky. install the front window guide. Note you might have to pull on the regulator gently to get the guide to pass.
9) push window guide through first rollers.
10) push window guide through second set of rollers.
11) install the front slide support. Note that the post for the guide goes behind the support. I made that mistake and looked for a nut for a little bit before I realized it...
Thats it. you now have your quarter window regulator installed. Next I will adjust the quarter window to mate properly with the door window and to go into the window seal correctly.
