Video reference, TF727 600hp rebuild
kiwivaliant
Member
Auckland
I found this on youtube today,
Apart from the god aweful italian-australian accent, it is actually a good reference video and free to view on youtube.
here is the channel;
http://www.youtube.com/user/Autotransmissions#p/u
Part 1: (rebuilding the 727 torqueflite)
Part 2: (removal of oil pan & valve body)
Part 3: (removal of oil pump, front clutch)
part 4: (removal planetary gear sets)
part 5: (parts needed for race torqueflite)
part 6: (oil pump disassembly)
"Part 6: 727 Oil Pump Dissasembly"
part 7: (727 oil pump assembly)
"Part 7: 727 Oil Pump Assembly"
part 8: (727 front clutch disassembly)
"Part 8: 727 Front Clutch Dissasembly"
part 9: (727 front clutch assembly)
"Part 9: 727 Front Clutch Assembly"
part 10: (727 rear clutch)
"Part 10. 727 Rear Clutch Assembly.wmv"
part 11: (727 one way clutch sprag)
"Part 11 727 One Way Clutch Sprag Assembly"
part 12: (727 rear servo assembly)
"Part 12 727 Rear Servo Assembly"
part 13: (front servo assembly)
"Part 13. Front Servo Assembly"
part 14: (front and rear servo arm assembly)
"Part 14. Front & Rear Servo Arm Assembly"
part 15: (rear gear train assembly)
"Part 15. Rear Gear Train Assembly"
part 16: (front gear section assembly)
"Part 16. Front Gear Section Assembly"
part 17: (front and rear band strut assembly)
"Part 17. Front & Rear Band Strut Assembly with Rear Band Adjustment"
part 18: (front band adjustment)
"Part 18. Front Band Adjustment"
part 19: (installing race valve body and deep pan)
"Part 19. Installing Race Valve Body and Deep Pan"
I am in no way affiliated with south-west auto transmissions, but i am greatful that they have shared the information they have, open source for the world to learn from.
possible tech article?
OK, this is cool.
I also have to be honest and I didn't see any part of any video, so, I'll trust in you there are no naked women running around or such items....a foul contained with in.
(LOL Joking joking...)
Nice find!
Uh, this has actually been posted on this board several times. That's ok, though.......it's informative
I watched these the other day and not even an hour ago had two 727's apart. A shorttail and longtail. Reassembled the short tail with the long tail shaft installed in it. Was done in two hours including dissasembly, reassembly, clean up. Super easy
That accent is painful to listen to. Some missinformation as well but for a noob there may be some good tips.
Very Informative , Having issues with my Newly Built Trans no drive on ground , drives on axle stands ?????????????????????
Is It As Easy as It Looks What are The Pitfalls, Ah You would not want to listen to My accent Then to Be Sure
Did my first 727 at 19. Took 5 hours from cleaning everything, working the valve body for the TransGo TF2, and pan on, ready to install. I used a Factory Service Manual. No internet then.
Ok I have Decided to give it a go Case and Usable Parts Cleaned , TCi four bolt Sprag Fitted
It was Very Difficult to get the rollers in , got there in the end , Drum turns Clockwise only,
I think I would go super Sprag Next Time
Peter at Southwest Auto's (who made the video) should be able to sort out those teflon seals you were after.
You know, it may not be his accent, but just your comprehension skills.. At least he bothered to take the time to make the video. What great deed have you done and posted for others to learn from..?
Cheers Got some from A&A transmisons also have a clutch retainer & springs coming from Cope Racing , Cheers
I watched one of the videos; the direct drum assembly. There are errors. NEVER machine the inside of the drum if it's scored from ring wear. It will be too big and the rings won't seat with enough pressure to seal on a hot SoCal day stuck in traffic on the 91; you'll fall out of high gear. This five plate setup is fine for 600 hp, but seven plate assemblies are available for under a hundred dollars.
How do you explain the operation of Teflon sealing rings then?
They have almost no tension at all and yet they work great.
I would say it is safe to machine the drum if it's not severe.
The video did not say how much stock was removed.
Probably a few thou would be fine. IMHO
Maybe if you didn't put worn out hard parts back into your transmission then you wouldn't be having sealing ring issues. And advising other people to put worn out drums back into their transmission is downright irresponsible.
What in Jesus name are you talking about.
Read the sealing ring thread I started before you answer.
The machining in the video is to fix the wear.
I never advised him to do anything. He's advising us.
I only asked you a question about how Teflon rings seal because unlike metal rings, they have no radial tension.
