Sully1190
Look. It's a Gold Duster.
that's because the question was the comparison of apples to oranges!
Or dollars to dollars.
oh the good ole' days , its threads like this i wish Stroker was still here LMAO
Bill,
So exactly how are you helping the original poster again ?
Either help the original poster,or build a car that runs.
Until then all your hot air is...well hot air.
Bill Dedman I think I know your coming from now you can take a near stock /6 throw on a turbo and beat most V8 and have a pretty Kool ride for a reasonable amount of dollars, but your still comparing apples to oranges.
you want dirt cheap >>>
73 duster slant six 3 speed car of which the slant six was pulled and tossed in a ditch
318/727 off CL for 400 bucks
cheap *** summit headers 120 bucks (optional) though you would need the correct manifolds
conversion mounts 80 bucks
88 lebaron radiator and shroud 40 bucks
performer intake , just because 75 bucks (optional)
1406 edelbrock carb just because 60 bucks(optional)
HEI ignition 50 bucks just because(optional)
drive shaft shortened ONLY because im using a 727 otherwise the slant shaft works with the V8 904 65 bucks
existing wiring, throttle cable and trans mounts
NOTHING ELSE was touched...nothing
i have just under a grand for the entire deal, including all new hoses, belt and fresh fluids.
this car is daily driven going on 2 years strong and it has taken a beating. it stops great on the drums, and ive tested them. for what it is , this little car boogies on down the road and is fast for what it is...bone stock 67 318 with a 4 barrel and headers.
bang for the buck? this is it. that ole slant could never dream of running this good especially for the money.
i did this by myself in 8 hours ....running
no, im not bashing the 6 cylinder
I'd hate to think it was all just for naught...:banghead:
That's pretty cheap all right, butr how much bang did you get for your buck (how fast is it?)
This guy put a Buick turbo (175$ at a junkard) added a 4-bbl l carb and a Clifford intake and ran 12.95 @ 104 with what is basically, the engine you threw away.
Is your car faster than that?
You're talking alot of cylinder pressure & heat build up. Also the fabrication time needed to install a turbo has to be considered. Induction piping & intercooler(another cost left out by the pro-/6 posters), custom exhaust, lubrication plumbing, & you wouldn't put all that into it without upgrading the rod & main bolts/ studs would you? A rebuild would have to be a given also. Forged pistons? Carb & intake manifold? You're not thinking about blowing it all through a little 1 bbl are you?
Pretty Much !!!!!!
Yeah, you're probably right; for some folks, it's a "you can lead a horse to water, but you can't make him drink" kind of deal... LOL!
To each his own...
The idea of building a slant 6 engine to produce the same horsepower as a 360 at whatever level, stock 360HP or a 500HP engine, and be cost effective in comparison is unrealistic. The slant 6 engine, while beffy & durable indeed in stock trim, will certainly show signs of failure or required upgrading & maintenance to survuive on 20# boost. You're talking alot of cylinder pressure & heat build up. Also the fabrication time needed to install a turbo has to be considered. Induction piping & intercooler(another cost left out by the pro-/6 posters), custom exhaust, lubrication plumbing, & you wouldn't put all that into it without upgrading the rod & main bolts/ studs would you? A rebuild would have to be a given also. Forged pistons? Carb & intake manifold? You're not thinking about blowing it all through a little 1 bbl are you?
The OP didn't express the desire to build a 500HP 360, but since the comparisions were made as to cost effectiveness, you certainly can build a stock bottom end 360 to produce 500HP & a set of iron heads w/ mild porting W/ an inatke, carb & headers that can easily be street driven within a reasonable budget. Probably using a bunch of used parts from this site or ebay to lower cost more. Trans & rear upgrades would probably be on the list of upgrades for both builds so thats a wash.
To each his own. I appreciate the guys that take a 1 off combo & build it to run well. Unlike the majority of posters here I also like the guys that build the Hondas & other imports to run good #s. It's all hot rodding. But as we ALL know it almost always costs you 2X as much to do something as you originally think. IMO the parts & techniques are there for the V8 build over the six from a time & money standpoint.
Why do I have this feeling that the original poster is looking at Nova's on Craigslist ?
It's all good Bill,believe it or not, I'm pulling for you.
I don't want you to think I am a /6 hater. If I was,I would have yanked the slant out of my 65,and thrown it in a ditch long ago.Actually,if my car wasn't
1-23 built,it would be in a ditch.lol But that's besides the point. I have built a fun
Slant car,with pretty impressive performance for what it is. With the 4spd it's a hoot,and I'm happy just the way it sits.
But if we are comparing apples to apples, my 360 car is a whole different beast.
I'll just leave it at that.
To the OP'er you should of called the tread "how to get V8 power out of /6" since no ones given you detailed mods, like which cam, header, carb, turbo etc..... Too use.
Bill, I think you are kinda making my point here for me as to the cost vs power of the boosted 6 vs 360 to get to 500HP when looking at the build here. I'm not saying it can't be done & I'm certainly not knocking anybody who wants to go the turbo 6 cyl route, but there is a lot of time & parts not all that common when compared to the V8 swap. You can easily build a 360 to make 500hp using cast pistons & a set of ported "J" heads & bolt on parts.
If it's purely based on economical factors I believe the advantage has to go to the V8 swap. Even in a build that goes for 300hp. Something does have to be said for a slant 6 & the wow factor.
Again, I think it's really cool that guys take the road less traveled & make a slant 6 run it *** off! Thnking outside the box is what makes it better for all.
Rock on my friend!
I don't think the OP'er was looking for a drag car so instead of turbo i think a blower would be a better alternative would make your car feel like a V8 right from idle.
