6pakattack Time
Gotta love positive thinking !!! Got my little goodies for my dash wiring,so maybe I'll get lucky and start on that this weekend ?:cheers:
It's more than positive thinking; it's the truth.
There's absolutely nothing wrong with a half-inch fuel line to your mechanical pump.
Quit whining and get busy; I wanna see that thing on the strip!!!:happy1:
(Listen to me; you'll probably have your car on the starting line before we get ours there...)
I second what bill says plumb it in and you can reduce your fittings down and call it good when I was setting up my fuel system I made capable for 1000 hp way more then my little turbo toad will ever put out but there's nothing worse then having to do things multiple times I running a 1/2 feed and 9/16 return just food for thought
Aaron,
I like the way you think.... LOL!:blob:
Picked up another piece of the Buzzin Half Dozen today today ! My New Radiator Overflow Tank !!
Been at a kinda standstill for a bit,just need to get the head (mine) right again !!
Wow, Dennis, that is just TOO COOL!!!
Love it!!! :):cheers:
Just went through this thread.. Great Job man! That engine looks amazing, Ill bet it runs as good as it looks.
OK,we got some crisis situations out of the way,and trying to build my spirits up. Got my fingers crossed that I'll be getting back on task with the Dart !! Try and knock out some of the PITA tasks this Saturday !!Wish me luck !
The best sent out to you, Positive thoughts :glasses7:
Wholly chitt,it's been a while since my last post !!!Well I think I've gotten to the point where everything I want to do is NOT done.However,I'm at a point where I can do a final tightening of everything and get it to the Break-In stage !!Change a couple of things so it's opperable,and I can worry about the fineer things later !!! Time to feel like I've accomplished something and enjoy it !!! So this weekend,despite being one of our cooler ones (high of 61*) I'm gonna pray for a badd *** sounding slant 6 !!!:burnout::burnout:
Well,have a bit of a timing glitch,so time to back up a bit and take things step by step and see what we can remedy !!:banghead:
It happens. Don't beat yourself up to much. Least you haven't had to redo the intake gasket 4 times like I did.
I forgot what ignition you are running smart move on baking up and take
a closer look at what is going on, one step at a time is the way to go when you have
dun so much great work already... no vacuum leaks...? sorry just had to ask:glasses7:
"... no vacuum leaks...? sorry just had to ask"
I was already to tell you I don't have to worry about that as I'm running a Mallory UniLite Dist.But now that you mention that,there was 1 line that I was going to need to plug on the Carb (vac line I'm betting)that I didn't plug,and I'm betting my buddy didn't either !!! THANKS for rattling the Rocks in my head !!! Do also have to figure out why the ignition key isn't working either,because it was before dismantling !!Again Mike,THANKS !!:banghead::banghead::banghead::banghead:
Thank you :D wow! I feel like I am not just a pretty face around here now :toothy1:
Keep at it and enjoy this great build :thumleft:
Well Mike,it wasn't a vacuum leak.It was way outa timing !The guy that built my motor came by and pulled the dizzy and farted around with the collar on the Mallory dist,and we now have ignition !!! Damn she sounds awesome !!!! Now to get to work on hooking up my GV overdrive unit,bleed some brake lines and install my New gauge pod and maybe I'll be ready to rock and roll !!!
:blob::blob::blob:
Horraayyyyy!! groovy news tonight, one step closer :burnout:
My daughter did a video with my phone last night,but I don't know how to retrieve it to post it !! I'll have to wait 'till she gets home this afternoon !
Looking forward to it, I know now I am not the only one not updated on these new phones :D:D:happy1:
