Im thinking of using this gasket at 10.0-10.5 compression with alunuim heads, am I able to spray 150-200 NOS? Are there any other gaskets recommended for 4.375 bore (4.480 gasket) with .039-.040 range (will put my compression 10.3-10.5? My pistons are .02 below deck height and I'm trying to keep the quelch right for 74-75cc Indy heads. Or do I need to send the block back to the machine shop to have it decked? I have heard alot of issues with the FelPro 1009 gasket, is this true or should I use this one?
