hotrodhoodlum
X Nostalgia Drag Racer
I just found this article is this true ??
you are trying to gain wheel clearance on an A-body the spring location will not help unless you also plan to mini-tub. The tire size on A-bodies is limited by the inner wheel well not the springs.
