[FOR SALE] Small Block SP2P Intake manifold
drtybttr
Portland, Oregon
Rating - 0%
0   0   0
Looks to be in good shape. Has the smaller ports that are good for the 318/273 heads. Produces good fuel economy and low end torque. I don't see anything, stripped or damaged. Only modification is that the heat riser on the passenger side has been milled off. Odds are in this day and age you won't use it anyway. Could also use a good hose off, its been sitting for a bit. Thermostat housing included. $100 and the ride.
5th pic from the top.. the bolt holes for the thermostat housing don't look healthy. They look egg shaped on my monitor.
Are there threads in those ?
My apologies. I wasn't seeing the photo properly. What looked like weird rusty bolt holes yesterday is actually rusty bolt heads this morning. 2D photos will do that sometimes. Reminds me of a time when my avatar was a door mirror and someone thought it was a Penguin. Anyway... Good luck with sale
This is the best truck manifold I ever used! lots of low end torque and better gas mileage than the stock 2 barrel manifold and carb it replaced...
X2...I've got one on my shelf right now just hoping for a truck or mild car build sometime in my future. I'm planning on using a (cough/cough) Q-jet on mine. :icon_smi:
No problem.
