520ci 69 valiant 100 project
henry b
ANSONIA CONN 06401
started with a 69 valiant 100 2dr slant/6 170 ci 904 and 7.25 rear. this Is before the work started nice driver car but the scoop ugh. now some pics of what going on losing the hood trunk fenders and bumper and going all fiberglass. removed half the floor and all of the trunk to make way for the new frame and 4 link set up. going with a 12 or 14 point cage. the dana 60 will be done soon 4.56:1 strange spool as with the motor 520ci 12.8 to 1 indy heads and Dominator intake with a 1050 or 1150 carb hughs solid lift cam 651x661 lift with 1.6 rockers by 268 int and 272 ex dur on a 108 center line will be using welds draglites 15x4 fronts and 15x14 with 6.5 bs and 31x18.5 x15
thanks more photos
update the work is coming along a bit slower then I like but it's getting there
:glasses7:sorry I like the green also but I am going with a eye candy tangerine metallic or a candy orange. each one will have about 2 pounds of flake and about 4 to 6 oz of gold pearl to top it off. like this but more flake and gold pearl.:prayer::coffee2:
update as it going.
well things are looking up I just received a new set of Goodyear slicks from a buddy of mine 33x17x15 just hoping they will fit. they will make the ones for mockup look tiny. I will tri to stuff them in today to see how much room I have.
a bit more is done on it. and one of the too flakes that will be used on it. fire orange .008 laid over the top of a larger .15 light orange flake and top coated with a candy pearl gold.
a few more photos as the work is a bit slow going
well the new flat steel floor is all most done still have to fab up a new driveshaft tunnel to clear the rear loop and then it is time to hang the dana 60 and fab up the rear fire wall and trunk. then to finish what body work that's left no more fuel cap and rear marker lights. and then spray the bed liner for the floors and underside of the floor and rear pan. no carpet to get dirt on.
wish I still had that MUCH DEVOTION AND ENERGY ! keep it up .
