where to outlet my exhaust
YoungDuster
Canada
Getting header put on my 72 duster so figure ill get rid of the stock exhaust itll be 2.5 in pipes off a 3 in header H pipes with to flowmaster super 44 mufflers where should i put the outlet turned out in front the the rear wheels ?behind the rear wheels? straight out the back? And what exhaust tips should i use? Open to all suggestions Picture would be great
I like the factory look
Out the back. In front of the wheel will make you deaf, and behind it will rust your quarters.
I've had them turn down in front of the axle to save on the cost in the past.
It was far enough back that I didn't hear it resonate at any particular rpm.
If you have ever had a side exhaust do that it can be hard to tolerate if it
happens at your normal driving speed. Way worse than open headers
in my opinion.
Beautiful car, so looks like out the back it is i like those square tips they look really nice
-Nice tips cr. Yeah I like the factory tips too.
-If you send the pipes straight out the back, they tend to attract cops. 2.5s are loud, but not as loud as 3 inchers. I put turn-downs on my 3s with dynomaxers. Its tolerable until I stand on it.And Im the only guy around here with 3s, So everybody knows its me. Very distinctive sound.
out to the bumper. looks the best to me.. and you'll hear a lot less of it inside then the other places you mentioned.
To the bumper with turns downs tucked up tight. Round pipes out the back looks cheap and turn downs under the axle is loud inside. Was considering boom tubes out the psssenger side like a ford lightning truck?
Yep I got dual 3 inch exhausts as well with Summit Street & Strip muffler.
I have them routed out back with cheapo turndowns.
I might have them replaced with dual 2.5's with X-pipe, chrome turndowns and either magnaflows or dynomax's.
i dunno it has turn downs on it right now but i really like the square tips about how much louder are you talking with super 44s it seems deeper like a heavy rumble, less of a roaring sound
