[SOLD] Forged 6-bolt 440 crank
ProSport
Akron, Ohio
Forged 6-bolt 440 crank, it was all checked out and cleaned up by a machine shop a few years ago, then greased and stood up in a Summit Crankshaft bag for a few years, I just pulled it out for a photo. It comes with the 6 bolts also.
$125 picked up, $150 shipped.
I'm around the block from Summit Racing, 44305.
Photos attached:
It was checked for cracks and core shift/straightness, if that's what you mean.
If not, please clarify and I will look into it.
Thanks.
Ok thanks, I don't know a thing about that but if you tell me where to look I will check it out. I can also provide a photo.
Look on the end of the crank where the 6 bolt flange is. There will be a hole in the center of the crank. If it has ever been used behind a 4 speed transmission there will most likely be a bronze bushing inside the hole.
Does this help?
I'll check later to see if there's a bushing in there.
Does it have one of these part numbers stamped on it? Should be stamped on one of the counterweights. I think it is usually stamped on one towards the front of the crank.
2406240
3751899
3671242
3671283
3512036
2536983
There's only one place that appears to have had a number but it is not legible at all now.
Price is negotiable.
