JohnFM3
So last month I bought a 69 barracuda fastback from a guy on here. I am totally stoked on it and looking at engine swaps. In the end, I plan on a 265 Hemi inline 6, which will be based on the Jeep 4.0L fuel injection. I was going to throw a slant 6 in to get it running, but then last weekend I came across a screaming deal on 2 Cherokee's that I will be buying.
Both 4.0Ls, 1 4wd and 1 2wd. While I would consider a 69 awd barracuda would be totally bad, I don't have the financing to even consider that kind of project. But a fuel injected jeep 4.0L with the 2wd AW4 tranny and matching Chry 8.25 with 3.55 gears would make for a fun car. And the fuel injection harness and ecu would be in place for when I swap over to a 265.
So now I am looking to see if anyone has considered this to pick their brain and consider gotchya's in this kind of conversion.
I am also looking to see if I can run a CJ 258 belly pan which if I recall has the oil pick up in the rear and not the middle. With this, I may be able to just cut off the engine mount points on the slant six K frame and build for jeep engine. I know K Frame changes are needed. There are no options for me to purchase, I may have to build it myself. I do have the V8 K-Frame in the car now, and the prior owner sold me a slant 6 K-Frame as well.
This will not be the official build thread, I am just doing some brain storming and asking around. I will post a link to a official build thread when I start later this year. I still have a YJ (wrangler) to swap the engine in first...
