OK guys i still can't seem to get this pig to stay cool! It's a 440 stuffed into a demon. I put in a brand new aluminum 26 inch 3 row radiator with 2 10 inch fans and a shroud, new water pump, top hose and thermostat (195), filled up with pure distilled water. I have driven it a couple miles home at dusk when it was cool outside and it ran 195 perfect the whole way home steady cruise 40 miles per hour. Then today I just took it down to the gas station to fill er up which is right down the road. 80 degrees and a little humid, brought it back and took the hood off to check the tranny fluid, put the hood back on and went not even a mile and back and the thing was slowly climbing, i pulled it in and shut it off at about 230 ish. What is going on??
