Post your sound bytes here.
[ame="https://www.youtube.com/watch?v=mvIeLghwRDU"]1965 Barracuda - YouTube[/ame]
Sorry about fuzzy pic...recorded w/I-phone 5s..dunno..
318
Comp 268 xe
Dodge Dakota manifolds w/2' flexible extenders <temporary>
[ame="https://www.youtube.com/watch?v=7dlmHyFM2FU"]1967 Dodge dart idle and revs ( 280h ) - YouTube[/ame]
yes, i know the headers leak lol
1967 dodge dart
Dodge 360 Build
-1973 Dodge 360 block bored .30 over
-Scat crank and rods
-Keith Black pistons
-11:1 Compression
-Indy LA-X Cylinder Heads 2.02 intake and 1.625 exhaust valves
-Comp Cams Magnum 280H camshaft .480 inches of lift 230/230 duration @50
-Comp Cams matched valve springs
-Comp Cams Pro Magnum rocker arms
-Weiand dual plane intake
-Edelbrock 600 CFM Carburetor
-Trick Flow SFI rated balancer
This sound Byte is "under load"
[ame="https://www.youtube.com/watch?v=TcFWgjIB4gY"]1965 Plymouth Barracuda - YouTube[/ame]
just post a link to your car running with the engine & exhaust specs
[ame="https://www.youtube.com/watch?v=dsJI17C5Qs4"]1967 dodge dart 280h comp cam idle - YouTube[/ame]
Dodge 360 Build
-11:1 Compression
3in exhaust with dynomax ultraflo's
452 CID RB
280/484 HYD CAM
Hooker fender well 2" competition series
3"with X pipe and Flowmaster 44s
dumped at axle
[ame="https://www.youtube.com/watch?v=SQ8ByyYIWS8"]75 Plymouth Duster 452+6 Idle, Burnout, Return...3" X-Pipe, Flowmaster Mufflers - YouTube[/ame]
vbpgimage.php
[ame="https://www.youtube.com/watch?v=h_KDWD7oRYY"]73 dart 360 - YouTube[/ame]
73 dart
'76 360 block
.040 over, stock style pistons..
stock crank
home ported heads (not extreme)
Crane 280 .480/.480 cam
Comp 901-16 springs
Summit? headers (I can't remember where I got them)
2 1/2 exhaust with universal x-pipe kit and thrush chambered mufflers dumped before the axle.
I just received my Accurate Exhaust System for my 69 Barracuda droptop with a slant 6 from Accurate Exhausts in Oregon. Very happy with it. Talk with Butch or Tom. They also have a FB page and website.
i think i might have a great idea :!: . today it dawned on me that alot of the questions in the mopar exhaust section related to one common theme. what kind to buy, and what do they sound like? well i have watched giggy's duster video, and thought this is the kind of stuff that really helps. i think this video should be sent to the mopar exhaust section as a stick thread. anyone else that has either videos or just sound files of their set up could then post to this data bank. the posts should list engine size, compression, cam specs, headers or not, tube size( if it applies) , pipe size, type of muffler, h pipe or x or none. i think these are the only things that contribute to the sound of the exhaust sound. posts can be either a video like giggy's or a simple wave file. length should be no longer than 25-35 seconds. should include idle quality ,and a few revs of the gas. (see giggy's it is perfect) :yawinkle: what do you think........ :thumblef:
Jeg's 2.5" exhaust system with their generic turbo mufflers. Stock 273 manifolds and headpipes. 5.2L magnum with factory EFI. I think the PCM needs to be flashed- cold start is a little rough.
my 72 swinger after break in, and before bodywork and paint.
.030 over 383
11:1
bowl blended 516s
.590 cam
street dominator intake with 750 mighty demon
open 2" fender well headers.
oh....it also had a wiped cam lobe
My old 2.5" exhaust with no X and no H on the newer motor. Had it on the run stand so I figured why not compare the old high compression motor to the new lower compression motor with that same exhaust since I changed it all at once at rebuild. The Cherry Bombs are really rusted out. Notice all the blowout on the concrete lol.
