Jonnylightening
Ok guys i bit the bullet and bought the EQ heads. My uncle has factory magnum heads on a junk yard engine (cracked block) so he said i can take whatever i needed from the heads. Before i desided to do the EQ head swap i bought a Summit cam/lifter kit along with mating springs. Questions i have are:
*what pushrods will i need (length)
*will my LA valve springs work
*can i use the stock magnum valves if they are in good condition
*will the LA valve seals work
If im missing anything please let me know im tryin to get an idea of what alls needed to bolt EQs to my LA
