Pushbutton launch control?
JoeDartGT
Active Member
So. CA
I seem to remember reading somewhere that the pushbutton trans can be used as a sort of "launch control" by loading it up and drive and dumping the brake. I don't remember the specifics, and I'm sure it's horrible on the trans, but is this true? Is this just a figment of my imagination and poor reading comprehension ;-)
You can do as you describe on any automatic, whether it's controlled by buttons or a lever. It will rapidly heat up the trans fluid and yes, it's very hard on the transmission. You can also do a "Neutral drop"—rev up in Neutral, then hit a button. Also very hard on the transmission and the rest of the drivetrain.
(There are lots of things you can do but shouldn't)
I love pushbutton transmissions, I had a 1963 new Yorker 413 with a pushbutton trans, the pushbutton controls were on one side of the instrument cluster and the heat/ac control!s were on the other side and they mirrored one another
I'd take it to the local oil change place, and as you know they have to drive them in and I'd sit inside and watch him first he'd reach for the column, then look at the floor........ By the time I would go out and rescue him he'd just be staring at the buttons trying to figure out what to do
Loved tire shops too"oh BTW that has left hand lug nuts on one side"
"It has what?"
God I love old mopars
loading the convertor / All dragracers do that to a certain extent ! some more some less , depending on what their running . Or did I misunderstand what ur saying?
The best thing about those push button trannys is being able to push or pull start the car if necessary. We rebuilt the 225 in my dad's 64 Valiant and couldn't get it to catch using the starter so we hooked another vehicle up to it and my brother pulled it about 20 mph then my dad hit the first gear button and that thing fired right up. He looked over at me and smiled. I learned something that day.
Any automatic with a rear pump will do that. Very cool thing.
