512Stroker
We are all here because we are not all there.
I am currently running the stock Mopar electronic distributor and orange box. Is there a way to add a rev limiter to this system without changing out the box?
MSD and Mallory both make rev limiters that you can use. Easy to wire upI am currently running the stock Mopar electronic distributor and orange box. Is there a way to add a rev limiter to this system without changing out the box?
Let me get this right, these new boxes are plug and play no changes to the stock wiring?Replace the orange box with a revNator box with built in Rev limiter. Sold by R/T garage. It is better ignition box with more HP potential than orange box plus there is no wiring changes. I have one on Duster that is drag car. RevNator has saved over speed several times. FBO also has replacement box w limiter.
