Gandy Dancer
Hello FABO - I just replaced my stock mechanical fuel pump on my 318 with a mechanical edelbrock pump, which I can see is working great and pumping fuel up through the glass filter which I am using. The problem I am having is that the car is not starting unless I am pour a little squirt of gas into the carburetor to get it started.It will run for a second and then cut off. The carburetor seems not to be pumping the fuel into the carburetor. Has anybody run into this before or does anyone have any recommendations? Thanks.
Thanks!
Thanks!
