Post pictures of ur race car here!
You should be on street outlaws "top 10 list" hahaha
sweet car
My junk !!
4.86 @ 146mph on 275 drag radials @ 3250# so far !!
588 with B1 originals !!
1 kit fogger with single cast intake !!
What are you using for rear suspension ?
That's getting it pretty good.
Beautiful car ! I've always dug the fastback Cudas.
73 Dart Sport Back half coil over ladder bar 440 .030 trw 2295 516 heads 750 alky 509 purple shaft 8 3/4 4.86 727 10"jw converter 1.43 60 ' best 6.96 99.8 run this bullet proof combo nearly 11 year
Here is ours..
My A body project
My current B-Body
Pic from 1992 or so. Very mild 440 pump gas, mid 11s.
New project, this time around will be a much more serious B stroker
Here's mine.......
Not really a race car but I do take it down the strip every once in a while.
73 swinger with your typical 400 hp goodies! I only ran it a couple times with the new motor and it ran a 13.2 at 98 with it laying down at the top.
[/URL][/IMG]
Updated pic. Color change comming soon.
Just got the new weld magnum rears mounted up, along with mosers.
Man I cant tell if im seeing drag cars or mudding 4x4 truck conversions. Why is it that mopar offer a way to lower their cars from the factory. Yet almost all mopars today are sitting so high king kong has to step up to get in one?? Seriously?? Cars go faster when they are lower to the ground. Just thought you guys should know that.
Then you should protect yourself from seeing vintage Gassers you will probably be frightened beyond your wildest nightmares:eek:
My street/strip ride, pump gas small block. Will run 6.30's in race trim and good air.
