These are from Chrylser convertible - made fairly easy brackets. Currently bought some factory buckets that I will be putting in although I thought these would have worked very well - Have since got factory console as wellAnd how did you mount them ...
Let's see um...
What kind of chrysler convertible, like a sebring, maybe a lebaron?These are from Chrylser convertible - made fairly easy brackets. Currently bought some factory buckets that I will be putting in although I thought these would have worked very well - Have since got factory console as well
got from pull your own parts. Chrysler TC by Maserati not sure of year around 1989What kind of chrysler convertible, like a sebring, maybe a lebaron?
What year was it?
Those seats look pretty good
Outside I was able to use existing tracks - inside I had to make an aluminium bracket on the front of each track as my car was bench seat and there was no raised angled pad. Car is not here currently I am having new quarter panels installed so I am unable to take pictures - sorryAnd how did you mount them ...
Let's see um...
Used seats very similar to those. Except mine came out of an 87 turbo chrysler le baron. Bolstering is more pronounced.These are from Chrylser convertible - made fairly easy brackets. Currently bought some factory buckets that I will be putting in although I thought these would have worked very well - Have since got factory console as well
Could be as I did not note other than Chrysler convertible. They were decent seats and cost $10 each so I just grabbed them. I had the back seat also hoping to take upholstery and use on original back seat but it was much smaller and was unable to do so. I was looking on line to see if I could find anything closeUsed seats very similar to those. Except mine came out of an 87 turbo chrysler le baron. Bolstering is more pronounced.
I just punched up Lebaron convertible and the seat look look to be match.Could be as I did not note other than Chrysler convertible. They were decent seats and cost $10 each so I just grabbed them. I had the back seat also hoping to take upholstery and use on original back seat but it was much smaller and was unable to do so. I was looking on line to see if I could find anything close
96 sebring Front and rear for my convertible. (wife wanted seatbelts. I wanted power)And how did you mount them ...
Let's see um...
