65 dodge dart gas pedal location v8
dazedand confused
hollister mo.
I have a 1965 dodge dart that came from the factory with slant 6 1 barrel carb and an automatic tranny shift on the column . Im getting ready to switch over to a modified 360 and it still has the slant 6 throttle pedal set up. I would like to switch over to the stock v8 throttle pedal set up if its not too expensive other wise i have a v8 throttle pedal with bracket for a 74 a-body car that i can install but dont know where to install the set up on the firewall?? Does anyone have a factory v8 set up? Anybody have photos to show me where either one needs to go? Both sides of fire wall etc thanks
The indensions are already in the floor for the factory V8 setup.
X3. Remove your /6 pedal assembly, peel the insulation back a bit on the firewall and hold the V8 assembly up. Line up the hole the cable goes through with the big hole in the firewall and you'll see the indents.
