AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,175
- Reaction score
- 13,517
Don't say bigger. no-no; don't say it. Nooooooooo. lol
You're not wrong, but that motor might be toast. He needs to dig into it and find out before spending a bunch of money that might otherwise go to a "possibly" more cost effective solution.
Hyupa "possibly" more cost effective solution.
Yes sounds like a typical craigslist sale
I'm not happy. I figure new pistons are in order at the least. Does anyone have experience with cylinder honing tools? Do they work?
More like suicide instead of murder......
I was hoping worst case was bore and more pistons.
Might be a stupid question, but if I bore the cylinders, I would need to replace with slightly larger pistons, right? I mean, we’re talking thousandths of an inch, but that’s a lot in this case. Or would the piston rings account for the larger bore?
Can Re-Ring it with a ball hone and go again . . .
Maybe.
If you have a 7-1/4
I'd rebuild the 318 .060 over with sealed power smooth flat tops set in 180 degrees from standard pin offset (piston slap when cold, but you can live with it) and moly rings on a 400 grit bore finish, put some fresh 302 heads on it with a good three angle grind, get the intake milled, and use some .039 composite head gaskets. Add in a sealed power CS1019r set in at 100 degree ICL (Thank's Rusty!). Tack on a set of el cheapo headers and a pair of dual exhaust. Do a mild recurve on the stock distributor, about 16 degrees initial and 18 degrees advance all in at about 3000 RPM. With the stock two barrel intake and BBD, you will be very surprised at the outcome. Add a Weiand action plus and a 600 CFM Edelbrock AVS II, and you won't believe it's the same engine. If you have a 7-1/4, you'll have to upgrade it in the near future, even with the two barrel deal. This combination even tolerates the freeway flyer 2.76 gears well.
Go get a 5.,9 magnum that runs and you way ahead of the game as far as cost goes.
Boring the thing is going to cost 400 for the piston and ring kit, gaskets etc. The machining is going to run you 500+. At that point, are you done? I doubt it. Get something cheap that runs, then take the money you didn't spend and build a motor from the ground up properly. Heck, you might get lucky and find a running 318. Change nothing and keep going.
Hey everyone, this is my first post regarding technical advice. I tried using the search feature, but I think this situation might be too unique.
I'm new here, and new to Mopar vehicles. To be honest, I'm pretty new to old cars in general. That being said, I have a '71 Plymouth Scamp with a 318LA, 904 3 speed. Was running fine, I installed some headers with a dual X-pipe exhaust recently. Still ran fine, but started to overheat on shorter and shorter trips. After having it towed, I discovered a clogged overflow tube to the coolant reservoir. I repaired a few leaky areas, but upon attempting to start it up for a test run, it wouldn't start.
I checked a few different things and ended up at the spark plugs. The electrodes were smashed and the tips were pinged. I pulled the heads and found the same with the pistons. Valves seem ok. What I did find, other than the damage, were some small, pellet sized pieces of steel in each cylinder (about 3/16" square). They're somewhat uniform in size and shape. They seem to be hardened steel, as they do not file easily. What I can't seem to figure out, is where they came from and how they got into my cylinders. Only thing I can think of is foul play. What do you guys think?View attachment 1715383058View attachment 1715383059View attachment 1715383060View attachment 1715383061View attachment 1715383062
I do have a 7-1/4. Thanks for the great details. I already have TTi headers installed with dual x-pipe exhaust. Have an Edelbrock 600cfm 4bbl and Edelbrock 2176 intake that were ready to go before all this happened, but now they’re just sitting in the shop...
I would take the paperwork back and ask him what engine it goes with - certainly not yours. Make him sweat for what he did. Let him know even though you are not an experienced engine guy, you know what he did. It is obvious the paperwork isnt for THIS engine.Perhaps. Super nice guy, had a VERY nice GTX in the garage, and I’m maybe a bit more trusting than is good for me. He’s actually the one who told me about this forum. He probably also sniffed out my ignorance from a mile away. I might be one of the smartest guys in the room when it comes to woodworking tools, but I’ll admit I have a TON to learn about classic cars.
He included paperwork from the rebuild, I’ll need to dig it up. But yeah, the more I work on it, the more doubtful I am of WHEN the rebuild was.
And I’m very appreciative of the help so far. You guys are great.
I tried to commit suicide once...
Almost succeeded, killed the guy next to me...![]()
