[FOR SALE] LA block camshaft and lifters (purple?)
Jimmy-James
Phoenix AZ
Machine shop pulled this cam out of the never been run 318 motor I bought if Craig's list.
quick internet search shows it might be a Purple cam. number 1136 is embossed between the lobes.
you get whats in the pics. cam, lifters and box.
I can take more pics as needed.
$175.00 obo - plus actual shipping from 85355 (or local pick up)
That is not a Chrysler Purple Shaft camshaft. They don’t have numbers like that. Kim
I have no doubt that you’re right. On another post on FABO I saw the number between the lobes was ‘part’ number. That was what I searched “1136 camshaft”. I can not tell who the manufacturer is.
Also most mopar cams have some purple paint between the lobes. Another characteristic is that most mopar cams are bare shiny metal not coated with black coating. Early mopar cams did though.
Check the front of the cam on the front of the first bearing journal for any markings if you have not done so yet.
