[Found!] valve springs
forced 340
michigan
Hey guys. I figured I would ask here before buying anywhere else. I need a set of valve spring for my j-heads. The cam im running is a MP PS .528 solid. 1.5 rockers, stock valves, installed height is around 1.875", my retainer OD is 1.350", the guide boss OD is .750". I'd like to stay around 1.4" OD on the springs for rocker clearance. Thanks guys!
I have a set of Comp springs that might do what you are looking to do. They are 950-16, seat load 133lbs @1.900, open 332lbs @ 1.300, spring rate 333lbs/in, coil bind 1.200. I'm asking $75.00 + actual shipping, if you are interested, I'll get a shipping quote. PM me your info if you want a shipping quote.
if shipping isn't crazy, i'd be interested! not too much more at summit.
shipping to 48322 mi.
Have a brand new set of Trick Flows TFS-16914-16.
1.490 in. Outside Diameter, 366 lbs./in. Rate, 1.073 in. Coil Bind
