8.8 swap
Another rubber line. Look right up there ^^^^^^ Post #853
The one steel line comes back from the master and goes into a rubber line above the rear axle. That rubber line goes down to the axle and slits with a T or Y fitting and runs to each rear wheel.
Can I use the original mopar one for that?
This is what I need then?
This it the rear left it looks like the one dan posted is the one with the writing correct?
Yup. And the Exploder rubber line isn't going to reach. You'll have to take your car's Hardline out of its amount and get creative with the bend and a new mount.
That's fine I'm running all new hardline anyways. I am ordering all my parts for the rearend and got really confused with that I thought I only needed those two but when I took my rear end out of the car I knew there was another rubber hose in there
Ok so far I have both hose ebrake shoes ebrake hardware kit rotors and pads can you think of anything I'm forgeting?
I used 2 short explorer e brake cables. You can figure that out later.
Oh ubolts I gotta get those
What size do yall use?
Ford 8.8, lol. Guess yours are gone?
Oh yeah, your 7.25 shock plates ain't gonna work. Use Speedway 8.75 plates. They're for 3 inch diff's and the 8.8 is a little over 3. So you'll have to squeeze the u-bolts bolts a little extra or Matt is working on something. I squozed 'em. Again, lol.
I bought 83/4 shock plates will the standard 8.8 unbolt work with the 83/4 plates
I'm trying to remember all this crap we talked about months ago lol. I'm getting ready to order the pinion yoke and ujoint too I'm trying to remember what we said I needed I can't remember what thread it was in I scrolled thru this one and dont see it
There is alot of info packed into this thread lol it needs some page finders lol
Right? I used U joint 457. Standard Exploder flange. Forget the number. I'll dig it up tomorrow if you need.
Yes please I don't have the standard explorer flange i thought I had a screenshot somewhere of that conversation i cant find it either
Maybe this was it
That flange yoke is a 1310 is our driveshaft a 7260?
