1962 A body engine mount BRACKET
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
Took them off 2 years ago and I can not find them anywhere. I have what I believe is a correct bracket for the left side but I am pretty sure the right side is different than the ones I have (which takes a rubber mount that attaches to the bracket with 2 bolts). I think I bracket I need the biscuit attaches to the bracket with one bolt.
Anyone have a pic of the brackets or have that side or a pair I can buy?
I think the 62- 66 K members are the same for A body?
65 Barracuda SB
In both pics the one on the left is the left hand bracket and right is on the right. If you need one or both of these start a conversation.
I might have what you need, picked up an aluminum slant over the weekend and I know it has at least one of the mounts on it. I'm working in Houston this week but give me a call on Saturday, I'll go have a look at it. I think mine is a '62.
So those are correct for my 62 Lancer? '62 thru what 66 takes same brackets? When I search Rock Auto for the rubber mounts it shows a mount that attaches to the right side bracket with one bolt not two like yours and mine take. I have those brackets and their rubber mounts.
I guess the slant will drop in no problem but it sure looks off!
Based on your description it sounds like Rock auto has the pics mis-identified. The mount with two 3/8-24 attaching studs is for the Right side. The left is the one with a single 1/2-20 stud sticking out in opposite directions. If what you have matches the pic I sent, yes it will bolt right in to your Lancer with the proper rubber insulators. And yes, '62-'66 SL6 all use the same (pictured) brackets and the same rubber insulators.
Wow, triple post! Nice job
My internet is more wonky than usual lately. The downside of rural living, at least in SE Arizona. I saw that triple post and freaked out, but was able to correct it.
Thanks for the info. Last time I dropped in a slant was like 5-6 years ago. I admit I have pulled and dropped in maybe 8-10 over the decades but I have forget half what I did know!! lol
Pulling the slant out of my 62 Dart( B body) did not help as I get parts all mixed together!!
Thanks again slant guys!
Bill, I had a problem on the oil pump side on my 62. I had been running a 67 before, so it sounds like the 62-66 info is good gouge. There is a little kick in the early bracket not in the 67 up one. Here were my mounts. Left one is 62, right 67.
