Bellhousing
Richard Bryant
New Member
Cave junction
can someone tell me what bellhousing would work in my65 dart I’m putting a 65 poly with an A body 1965 A833 four speed, would a 68 318/340 dart la engine bellhousing work I want to use a 10.50 flywheel and clutch setup.
I can’t answer your question but will comment on your engine choice. A poly is a pretty wide engine; IIRC wider than a 440. A 440 is a really tight fit in the narrow early A engine compartment; a poly might not fit!
I didn't have to trim my seam in my 64 Barracuda for a 71 340 belllhousing. Brewers has the conversion parts to run a 68 up bellhousing, flywheel and clutch in an early A.
Yes call Brewers they will give you the details for what works, ie bell, fork bracket (pivot) , fork, Z bar. They have the knowledge and all big and small parts needed.
If not mistaken the LA engine SB bell will bolt right to the poly. I also plan to use a 10/1/2 fly. I will do that in a 62 Dart (B body) if I ever get to La. for the trade for the engine.
Yes thats where I’m sourcing mine 68 318/340 2843887 .
It fits with about 2” on each side,I’m fabricating fenderwell headers so that won’t be an issue manual brakes no problem there.
