[FOR SALE] Competition Cams Hyd Roller Cam
360PLUS
so cal
Camshaft is 23-713-9
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,800-6,400
Intake Duration at 050 inch Lift: 242
Exhaust Duration at 050 inch Lift: 248
Duration at 050 inch Lift: 242 int./248 exh.
Advertised Intake Duration: 292
Advertised Exhaust Duration: 300
Advertised Duration: 292 int./300 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.549 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.544 in.
Valve Lift with Factory Rocker Arm Ratio: 0.549 int./0.544 exh.
Lobe Separation (degrees): 110
Camshaft Gear Attachment: 3-bolt
Computer-Controlled Compatible: No
Grind Number: XR292HR-10
Valve Springs Required: Yes]
This set up only has 6 hours run time and 70 street miles
located So California, 93536 happy to provide more pictures
$300 shipped please pm
