will a super victor intake
Nat
Canada
and Street Demon 750 fit under the stock hood , running an air gap and holley 670 now and it fits fine , getting conflicting intake heights on the super victor . or is there a lower profile Victor model I can use ?
thanks
sorry 1970 340 dart
You can use a Victor 340 if hood clearance is an issue.
It Depends???................................................
....What kind of car are we talking about - make, model and year????
FWIW, I have the SB intakes written down at these heights, but double check me:
Ede Super Victor-6.30"
Ede Torker II-5.72"
Mopar M1 (sp)-5.56"
Holley Strip Dominator-5.50"
Ede Performer RPM-5.35"
Ede Victor 340-4.93"
Well.....I'll take a wild guess at the answer about the intake..............."maybe".
Ede Torker II-5.72"
Mopar M1 (sp)-5.56"
so victor 340 and air gap are the same height , guess that narrows it down . Not cutting the hood , Thanks
So that means that I was correct when I said, "maybe"???? I love it when I'm always right!!!!!!:thankyou::thumbsup::usflag::p:p:p
Come on RRR....take a wild guess....:poke::rofl:
riht cause i have an air gap with a 670 on a slant 6 and it's in a ford fairlane that's why i'm asking on the A body forum for the last year
I'm not the only FABO member asking for the year and model of your car. We can't give you a good answer because different models and years have different clearance issues under the hood.
Port match the Victor 340 to the heads, radius the plenum, and you will have one heck of a good intake.
thanks , victor is on the way will match them to the bigmouth heads . now have a fully ported air gap ready for the scrap pile . it dies at 5500 rpm just where it should be going up
I haven’t had a victor on for awhile as I have an Indy intake on now and a ported Super Victor before that. My son has a 1 inch spacer on his Victor340 plumbed to his lean out valve for quick warmups. Seems to like the spacer.
I know it doesn't always translate..but on the bench it sure helps that intake pick up!
