Stop in for a cup of coffee
Quiet on FBBO too. Facebook as well. Time to get busy doing something constructive.
I check throughout the day as to what is happening, but don't get to chat much. Today had to kill some time before unboxing another engine so I looked and nothing but crickets here....
Thinking of trying to change the front pump seal on the Demon as it leaks bad. While up in the air (jack stands) and driveshaft out, maybe the center section too??? Seems like a lot of work
Picked up the kitchen
You must be very strong.lol
Thinking of trying to change the front pump seal on the Demon as it leaks bad. While up in the air (jack stands) and driveshaft out, maybe the center section too??? Seems like a lot of work[/Q
Easier done on a lift.........
Just got a call from a buddy of mine that is into the used Mopar parts business. He is more into B and E body stuff but got a hold of a cowl piece and a front clip minus fenders and hood from a (supposedly) 70 Dart/Duster/Demon. I am going up tomorrow to look at it. I might be interested in the cowl part. It has a heater core which I may need and I can strip it and sell off some of the other parts. (wipers dash parts, pedals etc) depending on what pieces are left. The front clip came from California or Arizona he said it is really clean and rust free. I'm not interested in that but I will take some photos and may-be sell it for him here.
Mike, if you end up with this, I may be interested in a couple parts..
I ordered this shirt online and I wanted a 2XL. I got like a Large. I could barely get it buttoned. I contacted them and they suggested they compare the shirt with a one that I own that is the right size.
Got a bunch of work done, inspected a 79 corvette, ball joints, control arm bushings and 2 tie rod ends. They lined it up last year, and never called one part. Tires are scrubbing.
mustang, decided to pull valve cover on other side. One loose rocker. Think it dropped a valve seat. I shimmed the rocker to get it tighter, but it still has an odd noise. So, off with cover again! Buddy dropped off a tin cover to cut up
Sposed to get hot here for Labor Day. NWS doesn't mention wind direction after tomorrow's forecast. I get this feelin' the Santa Ana winds are right around the corner. Big high pressure over Nevada, Utah, Idaho, that should do it.
72 here. If the NHRA US Nationals we’re still going, I think it’d set all time speed records
