Rear Sway Bar Problem
jonn6464
1970 Duster
Weatherford, TX
Hey FABO, I'm looking for a recommendation.
Car is a 1970 Duster.
I have a Moser 8 3/4 with 489 case. I purchased a rear away bar but it appears that it will not work with the square shape and brackets on the Moser unit. When I mocked it up, it looks like the end link bars are not long enough to provide clearance for the sway bar around the back side of the housing. Also, with the brackets on the axle tubes, the u-bolts will not mount to attach the support/guide bushings.
Is there a sway bar recommended for this rear end? See pic below...
(Yeah, I know it's dirty. There's been a lot of dust in the shop lately. I plan on cleaning it all up. And, I know the wheels are too small for the disc brakes. The car sits on wheel dollies at all 4 corners to move around.)
Thanks for you help.
I doubt anyone makes a swaybar for that Specific rearend. Maybe mount the sway bar to the frame and drop the endlinks down to the housing? I've seen it done with Nascar-style bars.
Yeah, you're gonna have to do some "fabbin" on that.
View attachment 1715586907 View attachment 1715586908 View attachment 1715586909
Firmfeel Mopar Suspension and Steering Looks pretty close to what you need. The devil is in the details, so I'd take some measurements and call them up. They are Mopar guys, not mass marketers, so you'll be talking to someone that can help, or find out what you need to know.
The Firm Feel bar is also Frame Hung which is a much better setup anyway.
Break open the piggy bank though. They cost about Double what an ADDCO or Helwig bar costs.
Yeah, the one I have now is also frame hung. It's just not "deep" enough to get around the backside of the axle housing, due to the square shape and support brackets welded to the back. This might turn out to be a fully custom fabrication, just to get it to work. We'll see.
