[WANTED] 340 Block
siuauto
Joliet Illinois
I am looking for a 340 in standard bore or .020 over that is fresh out of the machine shop. Located in Illinois but willing to drive a reasonable distance to pick up.
I got one .030 over fresh out machine shop 8 yrs ago...been sitting could use a hone... has new brass freeze plugs and new cam bearings...hot tanked also.....$900 it's in SC....can palletize and ship by fastenal....also steel crank avail and big valve J heads
Thank you for your response, my pistons are for a .020 block which is why I need it to be standard or .020 over. I wish your block would work for me.
10-4..I figured you already had .020 slugs...no problem and good luck!!!
I’m in St. Louis if you want a 20 over I have three that could be done. None have been to the machine shop they are std bore I get 500 with caps and whatever the machine work is
There are 10 in Nevada! Would ship im sure.....@GTX JOHN
I’m sure out of ten you can find what you want
What years do you have and could you send pics? I have no problem driving down to STL to grab a block
They start at 67 and go to 73. None are cleaned they are oily. Are you looking for a year or just a 340? The bulk are 69 year
Let me put a mic on the 71 I don’t remember it’s condition. I’m going to indy and could meet you in Springfield if this works
I have a spot. Anything else you need let me know I’m taking more big block parts than 340 stuff but I have plenty of small block parts too. A-B and truck parts
Do you have any suregrip center sections? 3.55, 3.73, 3.91
Do you have any interior parts for a 87 D150? most of the plastic trim pieces are broken so if you you have any, let me know
Also, I'm putting together a 70 Super Bee and I think I am going to be missing some body bolts and trip clips for the the windshield and back window trim on. If you have any of these, I would be interested
I have a good 741-391 suregrip what color trim and I do have clips
450 for the suregrip-it was in my pickup working great and I changed to road gears. I’ll check on the blue pieces.
I’m also looking for std bore 340 block if you still have one thanks
Very Interested in the Suregrip. Would you mind sending pics of everything when you get a chance.
Sure-I’m in Montana right now and as soon as I get back I’ll post them
