I also polished up/painted the heater controls and created a radio delete out of the original radio face.
Removed the wiper motor, pivots, and wiper arms. The drivers side pivot was completely seized, which explains why the wipers didn’t work. The couple of times I tested the wipers, I’d see the slightest stammer in the arms, then id shut it down right away. It took three days of soaking in wd-40, and a vice and a heavy hammer to free it up, little by little each day. Both are spinning freely now. I may tap a grease zerk into the housing like others have done, not sure yet. Replacement bushings, etc will be needed. I’ll also be cleaning (wire wheel) up the wiper arms.
I also bench tested the motor at various speeds, as well as the “ park” position. The manual tells you all you need to know here.
Getting her done!! Been going through much of the same on my 14 yr old boys SWB 65’ D100. No stone unturned
Here are some dash painting pics... I used Eastman Trim Black, which is really great stuff and dries to a nice uniform satin finish. I taped over the VIN plate because I want to leave that with the original patina, as well as keep the embossing and Chrysler printing intact.
Getting a good seal at the interface of the dash and windshield took some extra care. The shape of the cardboard, along with some finely folded paint paper led to no overspray getting to the window.
Thank you! And thanks for staying in touch and for all your tips all over these boards!Great work all around! Wow, everything looks great! Nice touch with the 440 badge too.
Hey Jeff. Thanks! Beautiful car you have there!
Thank you!Hey Jeff. Thanks! Beautiful car you have there!
